Discussion: How Many Bags...?
123578
  • SuperTrampSuperTramp City 17Member Posts: 1,021
    Received mine this morning from Argos, it was also open.
    Heres what was in mine
    We bought a good amount of Lego Technics today and know we have a good portion of the Mercedes Unimog #8110. How many bags of each number?
    @AFFOL_Shellz_Bellz I just received my Unimog from TRU today and here's what it has:
    7x #1 bags
    5x #2 bags
    1x #3 bag
    3x #4 bags
    3x misc. bags for the battery box, motor and pneumatic pieces
    Plus the 4 tires and rims.
    Let me know if you need any additional info.
  • graphitegraphite USMember Posts: 3,275
    #71006 Simpsons house has
    2x #1 bags
    3x #2 bags
    3x #3 bags
    3x #4 bags
    3x #5 bags
    2x #6 bags
    3x #7 bags
    plus 1 unnumbered bag with the bigger plates in it.
    SquareSidesidersdd
  • JeffHJeffH Member Posts: 173
    Here is a photo of all the bags and hopefully you can separate them.
    @chuckp Thank you, appreciate the help!
  • legofanfromleedslegofanfromleeds legoland...England Member Posts: 414
    Hi all.. im hoping one of you might be able to help. I recently bought a new set from argos in there recent sale but unfortunately it was delivered open.. can anyone confirm if I have all the pieces please...
    x 2 manuals. ..x 1 sticker sheet...x 4 sealed bags numbered 1 - 4 and x 3 loose plates ( x2 tan x1 green).
    Id be very grateful for your help in this matter..ps is anyone aware of any sites that might hold this information on any data base rather than piece count..
    Thanks in advance
    @legofanfromleeds, you can check the thread "How many bags" and also the bricklink inventory page, where it shows the # of booklets (also the weight if you want to compare).
    Thanks for that, I owe you 1
    l="Venunder">79003-1: An Unexpected Gathering
    2 instruction books and one sticker sheet.
    4 large bags each containing 2 smaller bags.
    1/ Bilbo i/ head and feet ii/ hair and other small peices.
    2/ i/ bottle and trans orange brick ii/ window grills.
    3/ Balin and Bofur i/flowers and tools ii/carrots and cherries.
    4/ i/ Bombur ii/ Dwalin.
    I managed to find this set on sale at argos ..uk but the box was open..I have everything as mentioned except there's no mention of 3 plates ( x2 tan and x1 green ) is this correct or should there be more or less..many thanks for advice in advane
  • legomattlegomatt Member Posts: 2,543
    edited February 2014
    @legofanfromleeds
    I don't have any specific answers to hand, but don't the instructions tell you which bag to open at each stage? If you flick backwards through booklet 2, you should eventually come to a numbered bag illustration, which would be the final bag for the final stage.
    ^ The instructions don't tell you how many of each numbered bag there are though.
    Thanks for the advice and your quite correct about the numbered bags..they tally with the book but also loose in the box where x3 plates...I just have my fingers crossed that nothing else loose in the box as escaped in transit ..so thats realy what i should be asking the community ie what wasnt in a bag when opened
    I hadn't thought of that. Is there often multiples of same-numbered bags? I don't recall.
    Yes, in most larger builds, lile modulars, #10240, #10234
  • VenunderVenunder Grimsby, UK.Member Posts: 2,644
    @ legofanfromleeds yes sorry 2 x tan 8X16 and 1 8x16 Green plates are also in the Bag End set.
    http://cache.lego.com/bigdownloads/buildinginstructions/6036617.pdf
    Anyone know how many bags for @7783, I purposed one with the box very slightly open, but the bags appear intact, would like to check they are all there.
    Nobody? I have found reference to 19 and to 20 bags and even one reference to 21!
    @Daragh I'm very jealous of your find. Have a look on youtube to see if one of the people doing a review on there empty the contents out before showing the build. You could weigh the box to see whether its what you should expect (see the Brickset #7783 for information)
    ^^ Looks like 21 bags plus 4 loose plates, a long tube and a sticker, two manuals. Here are the pictures of a review. Good luck:
    Great thank you @JeffH, I hadn't found that review. Although my box is slightly open, it is barely enough to get the bags out so I didn't want to take them out until I know what to look for - here goes.... fingers crossed.
    Finally got the courage to open the box enough to get the bags out and found the instructions and sticker sheet a little creased and 19 bags. I am still not sure anything is missing though, the bags are all sealed and they are different to the pictures above, also my mountain pieces are all loose. The minifigures are all there so I can't see anyone bothering to pinch something else. Photos of my contents below.
    Seeing the parts in the flesh I have discovered that I might have another 7783, although definitely incomplete, in a bulk lot I get recently and am still sorting :-)
    ^ It is definitely a different batch run as the content was definitely packaged differently but key parts can be identified.
    @JeffH I am going to hold off building and see how much of it I have in this bulk lot and then maybe keep the sealed bag set. Cheers.
    I managed to get a #10227 reduced from Toys r us but it was a display box so is opened. Can anyone confirm what bags, stickers, loose pieces I should expect in this set?
    Cheers
  • YellowcastleYellowcastle Northern VirginiaAdministrator, Moderator Posts: 5,234
    10210 Imperial Flagship
    2 Instruction Booklets
    8 Loose Hull Pieces
    19 Mylar Plastic Bags
    3 Soft Plastic Bags (Sails, Masts, Rope Ladders)
  • kw1980kw1980 Member Posts: 48
    Does anyone happen to know how many bags come with #7471 a friend of mine picked one up from a charity shop and would like to make sure the set is complete with possibly a view to selling it on.
  • Angel_CAngel_C Member Posts: 17
    Dear Bricksetters, can anyone help me out please? Does anyone happen to know how many bags in #10236 Ewok?
    Just bought a used Ewok set from a local garage sale. Inside the box, there are bags opened and some are still sealed. Quite a few pieces are zip bags. Can't figure out how many pieces are missing here.
    Please help? Thanks a lot in advance.
    Have a look at the set on the Main brickset site. You can access the instructions, although it doesn't tell you how many of each bag, the numbers go up to 11. From my memory from building the set there are definitely some multiples of some of these bags, plus a couple of big bags containing the larger pieces.
    Thank you so much, Msanders. Will just do as advised.
    Does the master list "Announcement" get updated from this thread? I keep forgetting to make note of this info when I part out sets or build.
  • bitaybitay Member Posts: 8
    Does anyone know how many bags are in Hogwarts set 5378? I bought one recently and not only does it appear light in the number of bags but some appear from different sets. Help please. If you know of where I can see a picture of the bags that would be very helpful. Thanks all!!
    Just received a damaged Orthanc with broken seals. Can anyone tell me how many bags? Thanks.
  • binaryeyebinaryeye USMember Posts: 1,809
    The review at EB says 15 bags and shows the contents of all.
    #10242 Mini Cooper
    2x bag 1
    3x bag 2
    3x bag 3
    #76023 Tumbler
    4x bag 1
    2x bag 2
    2x bag 3
    1x bag 4
    2x bag 5
    1x bag 6
    2x bag 7
    1x bag 8
    1x bag 9
    1x bag 10
    1x bag 11
    1 8x16 tile
    6 tires
    edited October 2014
    Do we have a bags inventory for #79018 The Lonely Mountain?
    If i recall correctly (i'll double check later, and repost if i'm wrong).
    Mine came with:
    1 cardboard-supported instruction booklet, with 1 small sticker sheet.
    6 numbered bags (1 to 6).
    2 loose-in-the-box rock pieces,
    Smaug split across four(?) unnumbered clear baggies (Head/mouth, some Tail, Wings, Body).
    Asking as my box appeared to have popped/tampered with seals (though nothing seems to be missing). Can anyone confirm inventory?
    ^ I had the same inventory in mine. I haven't built it though, as I bought the set for parts, but that seems to be everything.
    legomatt
    Cheers @matticus_bricks
    Yep. I really only bought it for the dragon (I can't have a hobbit display with no smaug), but otherwise will build once, then probably demolish for parts too.
    Shib
    #70816 (Benny's Spaceship, Spaceship, SPACESHIP!)
    7 bags total, numbered 1 through 7.
    Cardboard-backed bag of stickers/manuals
    Haunted House I unpacked yesterday had 21 bags in it (I didn't think to count how much of each number before putting them in the bin).
  • NeilJamNeilJam USAMember Posts: 272
    Can anyone tell me how many bags are supposed to be in #10682 Creative Suitcase?
    Does anyone have a bag count for #10232 Palace Cinema?
    I was able to dig out my personal copy easier than I thought I would be able to, so I can answer my own question:
    8x bag 1
    6x bag 2
    5x bag 3
    1x 32x32 red baseplate
    2x 16x16 tan plate
    1x 16x8 tan plate
    Instructions + sticker sheet
  • Pitfall69Pitfall69 0 miles to Legoboy's houseMember Posts: 11,454
    edited November 2014
    Can I still get the missing bags for the #10197 Fire Brigade from Lego Customer Service? The infamous 19R2?
  • oldtodd33oldtodd33 Denver 4800 miles to BillundMember Posts: 2,653
    I thought it was 39R1?
    Now I'm confused. Which number is the bad batch?
    39R1 is te confirmed of bad batch of #10197
    Ok. Thank you very much. So...can I still get the missing parts from Lego?
    Call Lego and ask. What are they going to do? Tell you no is the worst.
