Help from #10196 Grand Carousel owners requested
iso3200iso3200 97 miles from Brickset TowersMember Posts: 2,036
Seemed like a good idea at the time, but I started gathering parts from my own bins, and bricklinking bits here and there for the #10196 Grand Carousel. I could never justify spending the amount of money that a BNISB set costs, and I'm happy with a few substitutions here and there. I don't care for the sound brick either so that saves £100 on Bricklink.
Anyway.....
Most of the parts are easily found (relatively) but the one thing I can't do without are the 8 fabric panels, part 85195. Currently only 6 are available on Bricklink for £27 each.... again, no thanks. I want to make my own. I'll be experimenting with a few different materials, but what I need is a precise template to cut to.
Are there any #10196 owners out there who could provide me with an accurate template? Could you pop one of the triangular panels on a scanner with a piece of dark paper behind it and email me a file? Or trace around the outside of one with a pencil on a piece of paper and send it via snail mail? I'd be eternally grateful. If I can't make my own panels, I'll be wasting my time gathering all the bricks, and I don't want to start spending big on Bricklink to have an unfinished project at the end of it.
If anyone can help, please give me a PM.
Thanks
FollowsClosely
  • LegoboyLegoboy 100km furtherMember Posts: 8,704
    Have a chat with @Princedraven.
    He commissioned a company to create a like-for-like of the originals (or thereabouts).
  • iso3200iso3200 97 miles from Brickset TowersMember Posts: 2,036
    I've had some help already :-), and contacted @Princedraven too. I then come across a thread on this board from 2012 from @Erinlyn80 who was doing exactly the same thing. Don't know why I thought I'd be the only person attempting to Bricklink such a thing - I never even searched. Twit!
  • lfty888lfty888 PhilippinesMember Posts: 13
    @iso3200, were you able to get a sample of the fabric measurement?
    @lfty888 PM'd
    If you don't mind, please share the template in this thread for future reference. I'm planing to do the same once I've completed my custom Lego moulding machine.
  • bobabricksbobabricks Vancouver, BC, CanadaMember Posts: 1,839
    edited June 2014
    And if you don't mind, be sure to sell some new color parts once this machine is done ;)
    canon03
    Here it is.
    Pitfall69SirBenFarmer_John
  • jack_bricksjack_bricks Member Posts: 78
    hi iso,
    were you able to produce a look a like replica? Is it hard to find the exact fabric?
    I was thinking of taking a cape to a fabric specialist but I have no need for custom lego fabrics at the moment, maybe this would help for you guys though.
    I'll be honest - I've stalled a little on this project as a few others have had to be bricklinked in between :)
    I believe the material may be called broadcloth, but a google search does give quite a wide definition of this.
    I've worked in the graphics arts industries for many years and I know that there are textured papers that are similar - pros; very cheap - cons; not tear resistant. It all depends if you need it to be exact. Hopefully someone with a little more experience will chime in with the correct solution.
    I sourced some Tyvek sheets which is a lightweight synthetic paper, like very thin plastic which will work for me in the absence of the real thing.
  • ColoradoBricksColoradoBricks Denver, CO, USAMember Posts: 1,642
    Resurrecting an old thread that I had bookmarked in case one day I would want to bricklink the Grand Carousel… that day has arrived, those fabric pieces didn’t get any cheaper, it now cost 3x the RRP of #1096 just for a full set of 8 on BrickLink.
    Thank to @iso3200 's template, I created mine today after browsing the fabric shop. I put my pieces on the similar background than the picture above and I think the transparency is quite close to the original. The pieces are not perfect.. but the price is :wink:
    Those race buggys must have had a hell of an rrp :)
    Pitfall69
    edited March 2015
    @TheLoneTensor, well yes.. meant 3x #10196 :)
    TheLoneTensorPitfall69
  • Pitfall69Pitfall69 0 miles to Legoboy's houseMember Posts: 11,381
    My Grand Carousel is in a state of disarray. It is very flimsy. Also, if every piece doesn’t line up perfectly, the horses don't go up and down fluently and there are sticking points. I had to constantly adjust the whole thing until I got it perfect. Then I moved it and it sort of fell apart. I am not very happy.
    I think the key to making the carousel stable and working for a long period of time without having to reassemble and tweek often is to reduce the speed by changing the gearing. I did this with mine and it can run all day (or until the batteries run out).
    I also removed the scary sounding music brick and attached a non-Lego music box. Sounds way better.
