Please use our links:
LEGO.com •
Amazon
Are Legos made of standard polyvinyl chloride? The reason I ask is I am trying to determine an acceptable temperature range is to store them in. I realize that attics are not a good idea, but will they be okay in a room that regularly reaches 80-85 degrees Fahrenheit (26-29 degrees C)? Are there any other considerations for storage?
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
Quick Links
Older LEGO (from before 1963, or even for several years AFTER 1963, if talking about Samsonite LEGO), is made from Cellulose Acetate, and is more likely to warp. However, I'm not sure if it has the same atmospheric issues as ABS. I know CA is much more susceptible to problems, but I'm not really sure if excessive heat is an issue for it.
DaveE
I have several boxes stacked up in the master bedroom downstairs (much cooler), but the wife is starting to get annoyed. Limited sunlight upstairs and the legos are in boxes, so I should be good (except for the temptation of my kids to open the boxes). ;-)
As others have said direct ultra violet light -sunlight- can cause rapid yellowing, but so can darkness. The plastic is as ordered stable under normal conditions for a toy, this includes a day night cycle. According to LEGO quality control too much dark is as bad for some of the secret formulas of the chemical companies as direct sunlight is for others. I recently confirmed this by keeping what was a pristine old grey SHIP in boxes in my basement for three years when I unpacked it, it was about 25% yellowed. Keep your bricks in translucent boxes!
I guess leaving them in their original boxes is not good then? Very interesting...
Can you clarify "25% yellowed" does this mean 1 out of every 4 pieces changed color or all of the gray bricks changed hue by 25%?
Any chance the box was the culprit? I know in the art world, cardboard boxes are often avoided because they leach out acids that can yellow and damage paper.
BWT, really nice creations on your Flickr site!
