Seems like Lego is cutting more and more corners these days.
@mathew do you still have the box? Can you tell us the sealing label codes?
My guess is that it's partially due to stress from handling. I don't play with it per se, but I have picked it up numerous times by the hangar doors. Handling it this way would be pretty common I would think even if Lego doesn't recommend it.
I still don't think it excuses the poor quality of white Lego bricks as evidenced by other people's problems. It's a problem with 1x1 (various colors), cheese slopes (various colors) and I've even seen it on 1x2 bricks.
I wouldn't imagine that this could happen with rare expensive bricks of some sets.
That is hours of work for me testing each piece to find the bad parts, and then how do I know the rest of the white pieces won't crack soon (some crack immediately, others after repeated use).
It would have been ok if it was just a few parts, but in this instance the whole set is defect and clearly something was wrong in production (or alternatively while being stored at Lego/the Lego store)
I called them two weeks ago, and I'm still not finished finding the bad parts, if I ever get the time to send them. Crazy of customer services to expect such a dedication to help them with a defect product.
In other words, it isn't like the parts go directly from the molding machine into a bag, and since that isn't happening the batch number isn't terribly useful.
What would be useful is knowing specifically which colors and type of parts are cracking, because this set and others produce around the same time are likely to contain the parts made in the bad production run.
Here are all of the other sets that contain that element:
http://www.brickset.com/search/?part=4629913
What it all comes down to is that if your shuttle was bad, made of bad pieces, then the other hundred or thousand on either side of it are also bad. The codes are what link them.
My point is, the labels are very useful, nay critical to know. It's not the first time, nor will it be the last that those codes will let us know what sets are bad or potentially bad.
Another thing(s) to consider might be environmental conditions to which the plastic is exposed. For example, maybe dry climates leads to more cracking, or maybe moist climates lead to more cracking. Maybe someone lives near a highway, and high concentrations of diesel particulates or other pollutants aid in the degradation/cracking of plastic. Maybe the plastic gets too much or too little UV exposure, etc etc.
Just my opinion of course, but without a painstaking study taking into consideration a very wide variety of potential causes for cracking, it might be tough to discern the root cause.
http://www.bricksetforum.com/discussion/comment/21786/#Comment_21786
#10231 cracked peices. by ljmlego, on Flickr">
I have contacted CS about the issue and advised that I also have a seald copy of this set that I am concerned will have the same problem.
For what it's worth the box seal is marked: 36 R2
In the first picture of the bottom side. The replacement brick is on the left. In the second picture you can see how the new bricks are slightly more bowed. I can't make out the numbers on the bottom but this is clearly a different mold. I will now have to contact Lego and have them send out replacements for the rest of the bricks because its makes an obvious difference in the model.
And Obi-Wan's Starfighter, Hoth Echo Base, VW Camper, Imperial Landing Craft, Town Plan, Grand Carousel and 16 others.
I only have three sets with this arch on display right now (Camper, Winter Toy Shop, and Cool Convertible), and have been ever since they came out; checked them all right now and everything's fine. Never had a single cheese slope crack, either — or any part, for that matter —, but if anything that makes such threads more horrifying to me, not less. Too many people reporting, I can't be that one lucky guy.
@mathew LEGO makes changes to molds all the time, especially for possible durability reasons, but I must say I fail to see how this particular change would address your particular issue. (Though of course I am no materials engineer and can't say with confidence that changing that curve ever so slightly won't affect how the plastic cools down, resulting in better durability.)
