[US] Target: markdowns
norm103norm103 Member Posts: 297
edited May 2013 in Shopping USA/Canada
Hello was at target today and they had 3 sets marked down
4203 50% off
31007 50% off
6913 30% off
EKSam
«13456711
    edited May 2013
    If people are finding the 50% off sets in quantity, please consider picking some up for us to buy off of you for the US hospital donations.
    samiam391sidersddEKSamSirKevbags
  • margotmargot Member Posts: 2,310
    I've never seen clearance Lego at Target. Is it in the normal Lego aisle?
  • MilcheaxMilcheax Member Posts: 52
    Sometimes yes, it can be mixed in the regular Lego aisle.
    However in the locations local to me (6-7) they are more often at the end of the aisle.
    Not on the end facing the main "walking lane" but the opposite end that usually faces the puzzles and board games.
    In most cases the bottom shelf of the end where the Lego watches and cases (and other gear) sits, but sometimes on a nearby end where there's room.
    Most Targets I've been in have abolished their "full aisle clearance hidden in the corner of the store" so if your Target has one, check there too.
  • Thanos75Thanos75 Member Posts: 1,120
    I'm heading to the Target thats 5min away.....I will let you know what i find.
    Same sets and discounts in Troy, Mi. I picked up 6913 as I always liked it and had almost picked it up a few times on a whim at full price; liked it at $15, own it at $10:)
    There are a couple times a year it's really prevalent as in a "Target Toy Clearance Event," and then periodically throughout the year things will show up clearanced without rhyme or reason. For the bigger events, they will be in the aisles marked clearance with the big 30/50/70% signs. For the rest, they could be in the normal aisle, on endcaps, anywhere. Look for the red tags on the sets in either situation.
    Wow......I just got back and my target is wiped out. I'm actually surprised. Its always really stocked and have never not been able to pick up a sale item...hmmm
  • graphitegraphite USMember Posts: 3,271
    I just checked my closest Target and they don't even have shelf spots anywhere for these sets.
  • MorkManMorkMan Phoenix, Arizona, USA.Member Posts: 898
    Grr.... I'd really like #4203 for 50% off. Do you think if I called they would tell me if it's in stock? I'd hate to drive for no reason....
  • samiam391samiam391 A log cabin in PA, United StatesMember Posts: 4,418
    @MorkMan- Usually when you call and talk to a store employee/representative they are more than happy to check if an item is in stock. Usually all they have to do is plug it into a computer/scanner so it only takes about a minute for them to give you a reliable answer.
    ^ Provided you have the DPCI number for the item. Otherwise it's hit or miss with how knowledgeable the person is about LEGO or how helpful they want to be to try to figure out what set you're talking about.
    I've never had a problem. I'm always connected with someone from the toys department though, and usually they are at least somewhat knowledgeable.
    Everything goes out the window though with Walmart. They put me on hold for 15 minutes once and I haven't called to check product availability there since.
    I tried using the store locator and #4203 isnt even on the website anymore...the two creator sets are listed as "not sold in stores"
    My Target has #4204 The Mine 50% off...There were four of them when I went. I'm tempted to get one.
    Were they marked 50% off or did you have to scan them?
    They had the red clearance sticker that said they were $49 and change. And they were in the clearance section (an endcap of an isle). I'm tempted to buy and resell but I'll probably sit this one out.
  • not12fallnot12fall Member Posts: 65
    I picked up a #4203 at 50% off at my Target. There were a few on the shelves. They also had #31007 but that was only 30% off, so I left it behind. They were just on the interior end cap of the toy section under the 50% off sign.
    #4204 is a fun set. Picked ours up during the Walmart misprint fiasco and it was worth it.
  • cdollazcdollaz Member Posts: 6
    I just picked up an Attack on Weathertop for $17.98 (70% off). It was the only one and was located on a clearance endcap. No red clearance sticker. I assumed someone had just lazily put it there, but I decided to scan it and nearly crapped my pants when it showed the 70% off price. I then checked all of the other LOTR stuff on the LEGO aisle and nothing else was reduced. I'll occasionally happen on a LEGO set at Target at 30 or 50% off, but never 70% off.
    pillpodThanos75mathewmargot
    Well I did a store check on #4204 and found it at two of the local Target stores. I called and checked with the managers and both said that its not on sale....yet.... That the set is discontinued. I was told that they might go on sale but not sure when.
    My local Target Toy department guy told me that they regularly redo the layouts of different departments, and that's when you get a huge influx of clearance items. He said our Toy department wasn't due for a while, but that they had just redone the Electronics section and there was a lot on clearance. There was, but it was all junky stuff I didn't want anyay.
    Hmm, if the Mine has been discontinued I wonder what it will do this Christmas? It was a sleeper hit last Christmas. It's not the kind of set that they will re-do any time soon.
    I actually really really like the mine set. It was the first that I bought two of when I came out of my darkage. I have a big part of my town layout devoted to the mine. Its actually the main economic engine for my city. When completed it will connect to a refinery and to the docks and rail for shipping. I hope I can get another one or two on sale.
  • aimlesspursuitsaimlesspursuits USMember Posts: 207
    Found quite a few #6913 at the Desert Ridge Target in Phoenix. Didn't pick any up as I was hoping to find #31007
    edited May 2013
    It's hard to read just numbers or click. Small request to at least throw a small word ID to the set(s) you're talking about.
    SarahIsabella
    I stopped by my local Target to see if I would have any discounts.
    Most sets in the aisle were marked down a whopping $.90... with "price cut" stickers all over the place.
    I think the amount paid for the stickers by Target was more than the combined amount they discounted their sets.
    If you can wait until Sunday, supposedly there will be BOGO 50% on City. Those excavator transporter sets will be nice to pick up then.
    ^^My local Target also had miniscule sales. Most Star Wars sets and MF were 5% off. None of the City sets were on sale. They didn't even have the excavator listed on the shelf.
  • pharmjodpharmjod 1,170 miles to Wall Drug, USAMember Posts: 2,916
    Does anyone have the DCPI number for the listed sets?
    #4203 Creator Excavator Transporter 204-00-0490
    #31007 Power Mech 204-00-0601
    #6913 Creator Blue Roadster 204-00-1171
    I was able to get 5 of #6913 for 50% off and 3 for 30% and will be checking a few more places on my drive tomorrow. Whoever is handling the US hospital stuff let me know how that is being handled. I also have another speeder I got when ordering something to get the Iron man poly.
    pillpodEKSam
  • CircleKCircleK U.S. - Columbus, OhioMember Posts: 1,055
    Picked up the following today:
    #31007 power mech: $13.98
    #4432 city garbage truck $6.98
    They also had a single mines of moria for $55.00 but the seals were busted. #4203 excavator transporter was on the clearance shelf as well but wasnt priced and was still ringing at retail.
  • bige1998bige1998 Member Posts: 16
    What states are you finding these in?
    ^^ central OH
    edited May 2013
    The following Lego City sets are BOGO 50 at Target.com. #60004, #7498, #4209, #4439, #60003, #7288, #4432, #60016, #4436, #7279. Also GS #70702. In addition, most are on a slight sale although #60004 and #7498 are $8.00 and $16.00 of respectively.
    mrbradford
    ^ Looking at the online ad implies that all Lego Galaxy Squad are BOGO 50.
  • llanowarsoldierllanowarsoldier Ohio USAMember Posts: 357
    The Target Ad in todays paper says all lego is BOGO 50% doesn't list any restrictions at all. If that is the case I'm going to pick up some Creator sets.
    ^ I just stopped by my local Target. It's limited to Galaxy Squad and City only. I was tempted by a couple of GS sets, but even with a BOGO it's not a great deal compared to Amazon's pricing.
    Ackley
    Scored a single Lex Luthor Powerarmor for 25% off and the A-wing for $18, otherwise nothing tasty left. But did score on the Blu-ray Superheroes movie for Clark Kent fig at the awesome price of $13.99. The regular DVD is $19.99 on [email protected], so thought this was a smashing deal.
  • thenosthenos Twin Cities, MNMember Posts: 444
    There's a teeny tiny asterisk which refers you to the bottom of the page. Look again.
  • Penkid11Penkid11 Member Posts: 789
    It should be known by now that one should never buy a DVD of [email protected] Odds are every other store (including Toys R Us) will have it cheaper.
    On topic:
    Has anyone seen any of the new Galaxy Squad sets at their local Targets?
    I found a couple of ploybags at target today. #30014 and #30013. Picked up a few city sets and a GS set.
    I was able to find 3 of the #4203 sets at my Target for $19.99 and the BOGO. Wish they would have had an even number, but I'm still pleased I found it. Also, it wasn't marked clearance but rang up that way. Thanks @norm103
    Is the current Target BOGO a good deal or better then TRU's BOGO deals???
    Target is almost always better. TRU has higher prices from the get-go not to mention they raise the prices when they have a "sale." You must really pick and choose when buying from TRU. This is not to say that you can't get a good deal from them. I personally have worked the system to save lots of money through TRU.
  • odshowtimeodshowtime Member Posts: 49
    I went yesterday and found a 9470 for 70% off with no red sticker. It was in the endcap with some other Creator clearance items. That was nice I guess, not really looking to get into LOTR but the spider is cool. And at $5.98 you can't beat it.
  • starwarfan77starwarfan77 Member Posts: 341
    went to two targets in my area.
    no decent sale on any set at all.... one had #4203 but it was @39.99 :( i guess the markdown was for specific area target.
  • madforLEGOmadforLEGO Chicagoland USMember Posts: 10,473
    It must be nice to live near these mythical Targets that have quantities of these sets on sale and readily available
    Checkout two Targets and those sets were not even in the store, let alone clearance'd.
    I'm not sure if it is because of AFOLs with nothing better to do in the mornings stakeout all of the stores near me or what, but I never see many clearance sets at Targets or Walmarts for that matter.
    Jonn420Darthhenry1margot
  • sonsofscevasonsofsceva 1904 World's FairMember Posts: 542
    I found one Target with #4203 for $20 and they had four of them, so they were about $15 each with the BOGO.
    edited May 2013
    I was able to find two #31007 at my local Target.....while out shopping I found 3 #9468 Vampire castles at a Walmart for $69.....I picked up one. I am thinking I might go back and pick up the other two or do I roll the dice and see if they drop lower?....Hmmmm.
