So what you are after is probably more like the Haunted House in style, a one off building at the same scale as the modulars. Lego don't make one, they don't do religious buildings.
I suggest googling for images of lego churches, and follow the design techniques to build your own at the size you want.
Noted. I do understand Lego doesn't produce it.
I am looking for someone who has a custom modular church which can be connected to the existing modulars.
Buying instructions from eBay or BL and then source for parts is another option which I can also explore.
Regards,
Any thoughts on commissioning such a project?
I happen to know someone who was commissioned to develop a small church set based on a specific church within a community (in large quantities). It turned out very well. He even built and printed the Instruction manual.
If you're interested, please let me know and I can get you his contact information.
~PB
For example ...
http://www.ebay.com/itm/Church-Cathedral-Instructions-4-LEGO-Modular-Building-10185-10182-10218-10211-/271127133972?pt=LH_DefaultDomain_0&hash=item3f206fbf14
However, I don't think a church directly connected to other modulars will look realistic. You normally have a gap between the church and the neighbours.
Got to explore more before committing to one.
Let's just hope that the congregation don't want any light to come in though, since if it is connected to other buildings on either side then windows along the side walls will be useless.
Is that OK for you?
You.Just.Don't.Get.It.
It doesn't matter to me whatsoever, as I'm not the one looking for a modular church. I simply tried to link the OP with what he is looking to purchase. He wants to purchase a modular Church building, not suffer through your personal opinions.
It's.HIS.MONEY.
If there is no such thing as an actual LEGO modular church, the only way he will construct one or have someone construct one is by advice and personal opinions of other people.
I know you are trying to help/"protect" another member, like you always seem to try to do @PhoneBooth, however I think @tcleong can speak for himself. If he doesn't want opinions/help, than he'll tell us. In trying to say he doesn't want any help, you're actually doing what you are accusing CCC of :o)
Back on topic....
@tcleong- I'd also suggest googling LEGO churches to get ideas of what you may want. Maybe do a search of eBay.
If you can't find anything, let me know, and I could try to construct something for you in LDD. I'm not the best builder, but I do love modular projects.
However, there probably is someone who is better suited to this challenge, who I am sure will respond to this thread in due time. :o)
He can try to purchase instructions for a modular church MOC, but it is unlikely that he can since churches in real life tend not to have the characteristics of the lego modular range, in that they are rarely joined to other buildings. So when people design them and make them available, they are unlikely to make them like the modulars, but more like the haunted house, which is not a modular. It is a stand alone. Most churches have windows down the sides for letting in light. Connecting a church that has been well-designed with side windows directly to another modular would block out all the light coming in through those windows and just look odd. So instead of searching for lego modular church designs, I would advise searching for lego churches, without the "modular" part. That one word makes quite a difference. If he wants a dark church to fit in a row, he can always block the windows in and replace bricks with pins.
"Not to try and get involved in this cute little scuffle, but is all this really necessary?"
Then don't get involved...
Cheers!
http://www.virtualtourist.com/travel/Europe/France/Midi_Pyrenees/Toulouse-85892/Things_To_Do-Toulouse-Churches_Others-BR-1.html
All the ones I've seen seem to be of the local brick and have bells in the front wall.
You've inspired me to try to create a modular church along the lines of the local ones but it's unlikely to happen soon and I don't use LDD but just build, so photos would be all I'd be able to help you with.
Another way churches are built in downtown Toulouse is on the corner so that they have two adjacent walls facing the street. I think that you could make a more stereotypical church work like that.
All this is useless if you really are only looking to buy custom instructions that include all the bricks necessary to build the church. As it's a french style of building maybe you should search ebay France, or ask on whatever forum french LEGO fans use. My french isn't nearly good enough to have looked into those things, but in case your french is worse even than mine "eglise" is church.
Good luck!
Obviously though, as shown above, other countries do.
So it's all a big misunderstanding based on different cultures. Absolutely not worth having a go at each other about, especially as this forum is usually so nice and friendly. :)
Now kiss ;)
There's a beautiful Victorian church, All Saints Margaret Street, in London near Oxford St. It's jammed in between buildings but has quite an overpowering scale inside and beautiful Arts and Crafts decoration. Very controversial at the time, which was the height of the Gothic Revival, and critics claimed it looked like a hospital!
Worth a look if you like church architecture. I'm inspired to attempt it in Lego now!
BTW, everyone offers their opinion...ahem....advice whether you want it or not. It is the way of the Brickset Forum ;)
Apparently there *is* a Lego Certified mini-model of Durham Cathedral at the moment, available from at least one source on eBay: http://www.ebay.com/itm/like/301788583726
Not a size to fit with the modulars, but I'd sure like a copy of the instructions....
I'm sending @Pitfall69's attack church to settle this.
I'm not sure if they actually built it...
https://upload.wikimedia.org/wikipedia/commons/thumb/5/5d/St_Mark's,_Bristol_(April_2011).jpg/381px-St_Mark's,_Bristol_(April_2011).jpg
@paul_merton; @Renegade007cjh; @MattsWhat; @Bumblepants; @bendybadger
Ploppopcolypse!
http://www.thenorthernecho.co.uk/news/14097569.Get_your_own_Lego_Durham_Cathedral/
Perhaps you've missed the back-story. This is part of a multi-million pound project to open up parts of the cathedral site (don't think "church"; think "community") for visitors. The set is just a fund-raising exercise where you happen to get something as well - another is where you can "buy" bricks for the much larger model on display there. Any work on buildings this old (some date back almost 1000 years) gets very, very expensive.
It actually put me in mind of this:
https://www.guildford-cathedral.org/learn/history/brick-givers
