Please use our links:
LEGO.com • Amazon
The sorting methodology thread!!
I'd like to hear how those out there with large collections store and sort their lego. And how it affects your build methods.
I'll start. For large collectors I have a medium size collection (about 500 lbs).
I store all my Lego in sterlite craft carts. Specifically the ones with the drawers with lids, that slide out of the cart as a stand alone sealed plastic boxes.
I first have them all separated by color, each color gets its own cart. i then segregate each color along the lines of the brickset categories with a few small differences.
For minifigs I use the acrylic cases from the container store. Both the 2x7 and the 3x9 cases and display them on the wall.
This allows me to find whatever part i need fairly quickly, but does mean that to build anything i need access to allot of drawers of lego. How do you guys sort and store?
0
Recent discussions •
Categories •
Privacy Policy
How do identify a set you want to keep for display vs ones that you part out for MOCs?
From my experience if your MOCs usually cover about 2-4 colors, such as most castles, you're better off by brick, plate, tile blah blah blah because the colors are easier to judge quickly than say a black 1X1 and a black 1X2 in a black pile that cover over each other.
Anybody sell Legos by the lbs/kg? I have seen some auctions on eBay but they are usually for a rediculous amount and no guarentee of the type of parts (photo is general).
I also sort by size/shape. I try to separate grey/bley whenever possible. When I have to mix colors, I also like to mix contrasting colors. I'll have one compartment with black & white, maybe the next will have red & yellow. I only mix colors if I have a roughly equal amount of each.
I'm always moving things around - and I'll guess you'll do the same until you like hoe everything is organized.
This system works great for anything smaller than a 1x2 brick or 1x6 plate.
I just finished sorting all my small plates, tiles, cheese, and useful bits into some of the plastic tackle boxes mentioned above (Fleet Farm, a regional store, had them on sale this past week). You'd be amazed how many you'll need to sort out once you start building a decent collection of these.
It's interesting, now that they are sorted I find that I'm set on some colors, but really in need of other colors in certain parts.
And I'll agree with what someone said above, for small bits like that, sorting by element is more useful than sorting by color. For bricks, I find the opposite to be true (mixing all 1x1 and up in one color is more useful) because when you're building in one color it's useful to have a variety of sizes to alternate for stability.
Then I sort into broad shapes and leave it at that; flats, 1-wides, 2-wides.
For the themes, I just shove everything for each theme loose or built into a big box, sometimes grouping similar themes into the same box.
For minifig accessories / often used parts for MOCs (bushes, trashcans, etc.) I'm planning on buying a tackle box or two.
sorry the pictures aren't wider. my lego room is embarrassing right now. there are about 3x that many stacks of drawers, plus bulk brick and unsorted boxes. That help?
For most other things I sort by size then color. I have a bunch of the mulit-drawer Stock-On cabinets that hold things like tiles, mod pieces, round bricks, etc.
I actually have three tiers. The first tier is in storage cabinets 9 drawers high, of which I have 30-odd. There's one per colour (15 colours I think, bricks, plates, slopes, tiles, other common modnfied bricks) and the rest for specialist parts.
The second tier is bagged up by part and in chests of drawers.
The third tier, the stuff rarely used, is in various wardrobes around the house (much to my wife's dismay) or in the garage, in plastic boxes.
You can get a feel for the system in my Brickshelf gallery, http://www.brickshelf.com/cgi-bin/gallery.cgi?f=183620, but those pictures were taken 5 years ago when I'd just moved into my new house and I suspect my collection has at least doubled since then. I must take some more sometime...
http://www.evilmadscientist.com/article.php/efficientlego
I usually sort by size and colour or for smaller lots like orange or light green blocks I keep all together. Not that I have that many bits to sort...
I finally got around to sorting all of my plates into bargin bins I bought from Home Depot for a 1 buck a bin... So While I have these sorted and organdized (roughly anyway) by part type I find I have less space...
Plus having a GF with minor OCD helps too :-)
Bricks (maybe 1-wide, 2-wide and larger), Plates (usually 1-wide, 2-wide, larger and special shapes), utility bricks (including bricks or plates modified), people and tools, Technic, roof tiles and arches, wheels, large parts.
Each category has a drawer in my set of 123 drawers, which are each about 30cm square and 15cm deep. I put Ziploc bags of parts in the drawers and sort a drawer when it gets full. I also go to those drawers if I want 1 or 2 of a piece, to see if there is one there and hence save on sorting. Otherwise I go to a deeper store for a larger quantity.
I keep some parts that I use regularly in small drawers on my building desk. Deeper stores of these parts and stores of rarely used parts are in monotype or few-type bags in the other big drawers. I sort first by type, then by colour if I am likely to use a quantity of a single colour of that piece; otherwise most colours together will do, perhaps with black in a separate bag for frequent use. For the little drawers I might have a few of each colour one side and more black and grey the other side, deep storing the rest. This tells me I have some parts of each colour that is in the drawer, but I usually use black and grey more, especially for Technic models. If I buy PaB then monotypes can bypass the first stage and go straight into deep store.
I also have dedicated brick supplies for my railway layout, where bricks were bought specifically for that application. This uses large crates for bags of parts. Other similar crates, as well as boxes from Shop-at-Home purchases, are used for exhibition track and model transport. I also use smaller crates, especially for 1-wide bricks and for sorting, and also 2-litre ice cream tubs, though I am increasingly bagging parts that I stored in those and keeping them for sorting and for railway building (local supplies brought out of railway deep store to build layout modules).
Some pictures here: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=291134
The last pic shows the little drawers.
I recently started bagging set models more, to reduce the accumulation of dust from extended display prior to dismantling. If I buy a few of a set I would build one, sort the others and then dismantle the one before storing the bricks.
Recently I have also reduced bag sizes in the drawers so that it is easier to see bricks rather than bags. My system keeps evolving but unfortunately my purchasing manages to stay ahead of it so it's never completely sorted!
Mark
As I'm fairly new back into the Lego game, I don't have too much. I have a few stackable boxes (clear shoe storage boxes from Sainsburys).
- One has minifigs/accessories in.
- One has small bits (wedges/studs/printed tiles) in small boxes and base plates in.
- Another has all my PotC sets partially broken up in (as they are my newest sets, so I haven't mixed them in yet)
- The last one has all the other Lego bits in, all mixed up.
I'm fairly quick at picking out the pieces I want by eye, and have a bright green blanket to pour the tub out onto when I'm building.
There is another tub, but that contains a secret project I'm working on!
I sort by set and store them in ziploc bags inside drawers (grouped based on theme and size if possible) except for my Death Star, which gets put away in the original box. One drawer contains all my minifigures except for the Death Star ones, which remain with the Death Star in the box. I am running out of room though and I will have to come up with another storage method.
One thing I am struggling with a little is greys, I dont know if its my eyes or if some of the bricks i have are discolored or what but there seems to be lots of different greys, and I am finding it hard to differenciate between them. I have heard the term Bley and things which I assume means a bluish grey, but wondered if there is any kind of reference to the greys (not little alien men!) that may help me out, I tried googling but didnt really get far.
My concern is if I sort by type I can see me picking the wrong shade of grey brick and having it stand out like a sore thumb and having to dismantle/rebuild.
http://www.bricklink.com/message.asp?ID=544461
Also, a timeline of colors (using Bricklink names for the colors):
http://www.bricklink.com/catalogColors.asp
Anyone have a better way of storing manuals?
Something along the lines of what mbellis said - bricks, plates, utility bricks, minifigs, technic etc - sounds best.
Proving pretty hard work. Think I should probably generalise more and sort by brick, plate, tile, slope, arch, but will see how things go for now.
Sorting by color would mean ending up with, what 12 different boxes, but there are literally hundreds of types, so not sure how that works.
From what I read most people sort by type, but think I would need dozens and dozens of storage boxes if I sorted by type..
The main point is I think I can find a red 1x1 brick faster in a system that has 12 bins sorted by size and shape than I can in a system that has 12 bins sorted by color. In the color system, I might get to the right bin really fast, but then I can get slowed down hunting for the right part. I have a hard time discerning the shape of the brick when all of them are the same color. The edges are harder to see. In the type system, I'll get to the right bin relatively fast and then finding the right part is likely to be fairly quick as well. The different colors will create enough contrast in the bin to make quick visual identification of the shape easy. With different colors I quickly exclude the wrong colors. And with the things being the same size, the small parts don't get lost tucked between other pieces.
I sort for about an hour every day, truly (while watching movies of course). So here's my 2 cents for those medium to large collections...
Overall - sorting by color is a poor idea. Especially for black and white.
Step 1: I separate parts into 15 categories (Minifigs & Accessories, Bricks, Plates, Vehicle Parts A [wheels, windscreens, car parts, bases]; Vehicle Parts B [boat, aircraft, train], slope/wedge, inverted slope/wedge, modified bricks & plates; doors & windows; technic; bionicle; decorated parts; connectors (all the little clips); other A [tile, space parts like antenna, bars & fences]; greenery; animals; etc.)
Step 2: These 15 categories are then re-sorted by specific part types. Common parts get large Sterile pull drawers; all brick & plate sizes get their own space; the rest are given ziploc baggies by part type. For example, we use Sterile bins labeled Windscreens 1, Windscreens 2, Windscreens 3. These bins are stacked up for miles...
Minifig Sorting: Minifigs are really a whole separate subject. But here's how I do it.
Heads are put into those 20-compartment craft cases: Yellow, Multi-Color; Flesh separated. Then yellow are separated again by eyewear, multi-colors, white, then brown/gray decoration.
Torsos are separated by color (more 20-compartment craft cases); and then by theme - town, space, castle, sw, etc.
Legs - by color.
Weapons/Accessories - headgear (then by theme); city tools; swords, guns, headgear accessories (plumes, feathers), and the list goes on and on.
Sorting a light grey from a light bley is not that easy in the wrong light.
This is one of my concerns with the whole sort by type not color, surely if you are looking for a light grey 2x2 tile in a box of multicolor tiles, or at best multicolor 2x2 tiles it would be easy to pick a light bley out in error.
Maybe it is just me as I am still quite new out of the dark ages and maybe after a while it is quite easy to tell, but can imagine getting 1/2 way through a build and having to dismantle as I used the wrong shade of grey... :s
I'm a genuine believer that there is no 'right way' to sort; we all have our own preferences & needs, and we all need to find whatever way works best for each of us.
May sound silly as a bag is a bag, and they seem really cheap, but would rather not buy 5 lots before getting something that fits the purpose.
