You can of course remove them completely and try to get new ones.
Next time clean the area or apply the stickers before you touch the pieces. I pre-apply stickers on every set with stickers now.
I haven't encountered any issues with the image transferring off - so far, so good.
I would have thought it would be just the right consistency?
Funny that you've had that problem with 7964. I have had that same problem with the same set as well as 7163
I'm not sure if LEGO bricks even have any residue from the molding process left on them (releases, ect.), so just plain water never seemed like it'd be effective enough to bother.
Of course, it will also help if you're not supposed to apply a thin rectangular sticker to a round 2x2 brick (I'm looing at you #7787 )...and it also helps if the sticker sheets are not crumpled and bent upon receipt (TLG is getting a little better at this).
