Please use our links:
LEGO.com •
Amazon
Limited Edition? Star Wars Hoth Echo Base #7879
I did a bit of searching but couldn't find the answer, my question Is, what makes the Hoth Eco Base a "Limited Edition".
I believe it is a TRU exclusive, but there are other Exclusives and they are not limited edition.
Is it just marketing, or is it limited to a number of sets produced or is there something else special about it?
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
Quick Links
It would just be nice that if Lego are going to release a set and call it a Limited Edition, that they actually had a small write up online as to what it is that makes it limited. If there is nothing limited about it don't call it such.
It means that it is a store exclusive, or that it is only at select online stores like Amazon.
Luke's Landspeeder is hard to find because it is a Walmart exclusive, you can only get it from Walmart or LEGO direct.
I guess we maybe need to except that these are just labels applied to distribution channels. Whilst 'hard to find' to us in literal terms might mean something else, it's very different in this case.
Because they're only being offered at one retailer, the set is produced in a lesser quantity than would be the case if it were not exclusive. However, the production amount is still influenced by other factors, such as the size of the set and the length of the production run. There's every reason to believe that 8092 Luke's Landspeeder -- a Walmart "special edition" -- which has been available for nearly three years now, was produced in greater quantity than other sets that aren't "limited".
"Limited Edition", numbered: These are the truly limited production sets that are given numbers, i.e. 92 of 10,000. Famous examples of these numbered sets are original runs of UCS Millennium Falcon, Santa Fe Super Chief, Comic-Con and Toy Fair exclusives. TLG has announced very loudly when a set is numbered in production (they've even numbered posters recently), so there really shouldn't be any mistaking these from the "Limited Edition" sets at TRU. I think we can hold LEGO true to the fact that the boxed sets are limited in number as stated, but it is worth noting that the "1 of 10,000" Gold Chrome C3PO actually had more than 10,000 produced: http://www.bricksetforum.com/discussion/comment/11079/#Comment_11079
"Exclusive": A label used for sets that are available only through LEGO retail (LEGO stores, [email protected]) initially. Eventually (I'm not sure if there is an exact timeframe) most of the sets are sold at other retailers. The Modular Building series and UCS Star Wars sets would be the most known examples here.
"Hard to find": A label used by LBR that seems to encompass any and all of the above. It also has been randomly applied to generally available sets in the past, usually close to their retirement. LBR has recently introduced the "retiring soon" label, which may shore up the apparent randomness of "hard to find" if they are now categorically identified as being "limited", "special", "exclusive", or "retiring soon".
