Discussion: How Many Bags...?
245678
    Plate type...I assume there are three instruction books...
    Cafe Corner has 2 instruction books and 2 16x32 green baseplates
  • mcvitiemcvitie Sheffield, EnglandMember Posts: 292
    edited June 2012
    Just received Diagon Alley in quite a bad state, so Im worried that some bags might be missing
    The box contains the following
    x5 number '1' bags
    x4 number '2' bags
    x7 number '3' bags
    Can anyone please confirm that this is correct for this set?
  • JBricks27JBricks27 Member Posts: 678
    edited July 2012
    Can someone please verify the amount of bags and other pieces (blue base plates and dark grey road pieces) that should be in the box for 10214 tower bridge?
  • MatthewMatthew Cheshire, UKAdministrator Posts: 3,735
    mnbvc said:
    Tower Bridge has 28 bags (not counting the smaller bags inside the bigger bags). The grey road plates and the blue water plates are loose in the box. Hope that helps.
    All_That_Rocks
    5 blue base plates and 8 road plates I believe.
    Thanks guys
    Hi guys, can anyone please confirm number of bags in Tantive IV #10198?
    Also, how many bags in #10177 Boeing Dreamliner?
  • UKtsumiUKtsumi Member Posts: 627
    My argos ebay #5891 house arrived, bashed + taped.. just want to check how many bags there should be , I count 10????? thanks
  • CCCCCC UKMember Posts: 20,001
    It would be a really good idea if LEGO wrote how many books and bags there should be inside or on the back cover of instruction book 1. Most things whether flat pack furniture or multi-part toys come with an inventory you should look at before building - so why not Lego?
  • VenunderVenunder Nottingham, UK.Member Posts: 2,602
    Red Cargo Train 3677 has quite a lot in the box:
    1 bag of 6 instruction manuals and 1 leaf of stickers. With a piece of cardboard to keep them flat.
    7 numbered bags of lego.
    1 bag with 16 flexible track pieces.
    8 straight tracks in 2 stacks of 4.
    16 corner tracks in 4 stacks of 4.
    1 bag numbered 4581960 containing the receiver/direction switch (this is numbered 4566756 in the inventory).
    1 small cardboard box numbered 4621120, containing a small bag of 8 drive wheels (4 for the engine and 4 spares), a bag of 4 magnetic connector buffers, the engine, a battery pack and a radio controller.
    1 small bag containing a red cover for the battery pack, 8 x 4 studs, 3 and 3/4 bricks high.
    1 small bag of 4 magnetic connector buffers.
    1 brown rail truck tub, numbered 4631878 in the inventory.
    1 black flatbed for the red engine, 28 x 6 studs.
    1 grey molded trailer, 34 x 6 studs
    1 constructed conveyor belt. 16 x4 studs, 1 brick high.
    Now to start building it..... :)
    It is a short 2-3 hour build depending on how you concentrate. :)
    Hubby just built this also, but the base plate for the engine was missing, and it just arrived today so he was able to finish it. He enjoyed this build and the fact that it looks more like an American train.
  • iBartiBart Member Posts: 121
    edited July 2012
    9398 Crawler:
    (7 bags of parts and electric parts in separate bags)
    - 3 bigger bags
    - 2 medium
    - 5 small
    - 3 with motors - every in separate bag
    - 1 battery box + IR
    - 1 pilot
    - 1 manual/sticker sheet
    * In bags with nr 1 (two of them) are additional two smaller bags - in each.
    In big bag nr 2 there is one additional, smaller bag.
    Hope somebody finds it helpful. :)
  • atxleeatxlee Member Posts: 155
    UCS set 10212 Imperial Shuttle
    24 bags in all
    Anyone have the bag/content count for 10221 SSD?
  • RainingBoroSi02RainingBoroSi02 NCMember Posts: 59
    24 bags in all
    Thanks, I just a IS from Amazon Warehouse Deals that had been opened. Checked and all good.
  • drdavewatforddrdavewatford Hertfordshire, UKAdministrator Posts: 6,704
    I'll pass this suggestion on to LEGO via their Ambassador Forum.
    ^ That would be good. Especially for sets that have loose sticker sheets, or a piece that is not in a bag. They could just use a picture showing, for example,
    Please check the contents of your box before starting to build
    Instruction book 1 (this book)
    Instruction book 2
    Instruction book 3
    16x16 plate
    Bag 1 x1
    Bag 2 x1
    Bag 3 x2
    Bag 4 x1
    I doubt they ever really make mistakes. But it is nice for a user to check that they have everything that should be there before starting to build. I've occasionally had a sticker sheet that has got caught in a flap and not noticed it.
  • LegoboyLegoboy 100km furtherMember Posts: 8,835
    I'm not sure this a good idea. I know of two different 7191s I've owned in the past that had a different number of bags inside the box, yet both complete. The Beetle I recently built had two more bags than TLG told me it should have, yet I didn't have any more than the usual number of pieces left over. I questioned the bag inside a bag scenario with them but they said no it wasn't that. They said it was probably down to a change in the production run.
    To me it is clear that they change the process at some point during its production period, possibly because they have found a more efficient way of pack those particular pieces. To document that fact on the back of an instruction manual would cause chaos ie. an old stock of manuals packed with newly collated boxes of bags.
  • RennyRenny USAMember Posts: 1,145
    edited August 2012
    I will be receiving a sealed copy of Market Street. Any idea what the bag count is?
    Sandcrawler #10144 - 22 Bags and 1 Instruction Book.
  • turtle1173turtle1173 Member Posts: 230
    Can anyone veryify how many bags are in the Tantive IV 10198? I recently bought one cheap. It is definitely missing at least one bag but I would like to know how many before I can determine the parts I'll need.
    Thanks
  • langlang Member Posts: 16
    edited August 2012
    w.r.t. identifying the number/quantity of bags in the set in the manual...
    If the configuration of the bags/parts is subject to change, and putting specifics in the manual won't work, how about they provide a custom URI to a page on their site instead? That way, ordering a missing part/bag could subsequently be made easier (via specialized links, etc) and in cases where text explanations are required, can be multilingual without any printed overhead.
    Just a thought...
    edited August 2012
    @turtle1173 - Mine is not a sealed box either, but I counted 15 sealed bags in my #10198.
    Thanks @BrickDancer - I'm afraid mine hasn't worked out so well. Mine only has 9 bags :-( I spent about 4 hours today going through and comparing the sealed bags I have with a detailed review on Eurobricks. I think I'm going to scrap the idea of getting the additional pieces. I keyed it all in to bricklink today and I'm missing almost 650+ pieces. By the time I go through all the work to piece the rest together, I could just buy one for about the same cost.
    Creator Sonic Boom #5892 - 8 Bags and 3 Instruction Books
  • JoinceJoince Member Posts: 8
    So, what about the instructions books?
    ^The number of instruction books aren't usually stated either. So just thought I'd add that bit, since they vary quite a bit from set to set.
    Can someone confirm the contents of 10199 Winter Village Toy Shop? I counted 8 bags and 1 instruction book.
    And as a general suggestion, how about adding the contents to the database for each item?
    edited September 2012
    10229 Haunted House:
    3x instruction books (wrapped with cardboard)
    5x loose 8x16 dark grey plates
    2x #1 bags
    8x #2 bags
    4x #3 bags
    6x #4 bags
    1x #5 bag
    veign06
    10229 is Winter Village Cottage :P
    HH is 10228.
    oops - typo of course. thanks!
    Just got 2507 Fire temple and saw in the book bags 1-7 which is not many for 1100pc set. However, there's 10 in total,1 of each of 1,2 4,6 and 7 and then 2 of bag 3 and 2 of bag 5 as well as a bag containing the dragon head and jaw. Also, no loose parts
    3 books and no stickers which I was really surprised at. I expected the windows to be stickered but no. Instructions not in a poly with card - mine were slightly curled.
    Creator Beach House #4996 :
    8 Bags (Unnumbered)
    2 loose 2x16 plate yellow
    1 loose 16x32 baseplate green
    3 Instruction Books (not bagged)
    Star Wars - Republic Dropship with AT-OT Walker #10195 :
    10 Bags #1
    12 Bags #2
    1 Bag (Unnumbered)
    1 Sticker Sheet
    3 Instruction Books (Bagged)
    24 bags in all
    Great! It's a good confirmation from you for me as well :-)
    #10225 R2-D2
    3 instruction books
    sticker sheet
    loose plaque plate
    2x #1 bags
    2x #2 bags
    2x #3 bags
    1x #4 bags
    1x #5 bags
    2x #6 bags
    1x #7 bags
    1x #8 bags
    2x #9 bags
    1x #10 bags
    8110 Technic Unimog
    can anyone confirm the following bags (the lego seals on my box were broken/resealed with tape )
    7 #1 bags
    5 #2 bags
    1 #3 bags
    3 #4 bags
    also 3 bags containing pneumatics/motor/battery pack
    tyres + wheels were loose in the box
    thanks
    10223 Kingdom's Joust
    2 #1 bags
    1 #2 bag
    1 #3 bag
    1 #4 bag
    2 #5 bags
    2 #6 bags
    2 #7 bags
    1 #8 bag
    2 Manuals
    I didn't see any stickers (not sure if they are required since I haven't built it yet)
    Anyone knows how many bags does 10179 suppose to have?
    79 by my count...
  • hleonffuhleonffu USAMember Posts: 244
    9398 4x4 Crawler
    5 #1 bags
    5 #2 bags
    1 bag (unnumbered)
    1 bag with Infrared receiver and battery box
    1 bag with remote control
    1 bag with servo motor
    2 bags with large motor
    4 wheels and tires loose in box
    1 sticker sheet (in sealed bag with manuals)
    3 manuals (in sealed bag)
    Nice build.
  • Penkid11Penkid11 Member Posts: 789
    #9474 The Battle of Helm's Deep
    1 #1 bag
    1 #2 bag
    1 #3 bag
    1 #4 bag
    1 #5 bag
    1 #6 bag
    1 #7 bag
    1 #8 bag
    1 #9 bag
    That's correct, you read one of each bag.
    4 Manuals
    1 Sticker Sheet
    Both sealed in same bag
    79 by my count...
    Thanks LFT
    UKtsumi said:
    8110 Technic Unimog
    7 #1 bags
    5 #2 bags
    1 #3 bags
    3 #4 bags
    thanks
    Yes that's exactly what I have.
    ^ thanks for that,
    #8039 SW Venator-Class Republic Attack Cruiser
    15 Bags (Un-numbered)
    2 Instruction Books (Un-bagged)
    1 Sticker sheet (Un-bagged)
  • gmpirategmpirate Member Posts: 1,654
    dougts said:
    per http://www.eurobricks.com/forum/index.php?showtopic=31394:
    Fire Brigade has:
    10 x #1 bags
    8 x #2 bags
    2 loose 8x16 dark grey tiles
    pet Shop
    1 bag of large plates
    4 x #1 bags
    4 x #2 bags
    4 x #3 bags
    4 x #4 bags
    Ok, just opened a questionable Fire Brigade from a 3rd party via Amazon.
    10 x #1 bags
    9 x #2 bags
    2 x 16x32 dark grey base plates (loose)
    1 x 8x16 dark grey tile (loose)
    1 x yellow flex pole (loose)
    2 x instruction booklets
    Version 19R2. I don't remember which was from the bad batch.
