Please use our links:
LEGO.com •
Amazon
Brick Discoloration Due to Sunlight/Smoking and Methods to Restore
I have come into some old Classic Space and Futuron sets from the 80's, mostly complete too. :) But most of the white, grey and some of the blue pieces, (which is just about all of the pieces), have discoloured horribly. I suspect nicotine or direct, direct sunlight to be the culprit, as the larger wing sections are very, very yellow. Even some of the minifig's faces are discoloured where they faces are seen through the helmets!
Any tips on cleaning/restoring some what, to at least good enough that I can display them? I read that Hydrogen Peroxide works wonders, but is this just regular household bleach? Or is there some special plastic cleaning bleach that works better?
Has anyone had any success in getting these stains off?
Thanks.
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
I have not yet attempted to restore them, but am going to use these urls as my guide:
http://www.brothers-brick.com/2009/08/30/how-to-clean-yellowed-lego-bricks-to-make-classic-space-sets-look-new-news/
http://retr0bright.wikispaces.com/
I'll probably do some more googling too! When I do finally try it, I'll be sure to post the steps I took and photos of the before and after. In my head I think it'll never work, but from reading the forums, it sounds like miracles are possible!
I too am interested in hearing from anyone who has actually done it successfully - what were the exact steps they took - equipment, timings etc. I'm in Scotland so dont have ready access to sunlight :o)
Ally
http://gimmelego.blogspot.com/2011/04/bleach.html
I think a much more systematic exploration (different types of U.V. source, different durations of exposure, before and after pics, different concentrations of hydrogen peroxide, different catalysts) would certainly be of value, rather than my unscientific "bucket chemistry" approach....
I have extensive experience with this process. I've done old RC car parts, as well as Lego bricks. Here is what you do... you need regular hydrogen peroxide (30%), glass jars, and sunlight.
Fully submerse the pieces, put them in the glass jars and then put the jar in bright sunlight. About every hour, stir them around. Depending on how extensive the yellowing is you may see results in as little as hours, or it may take a few days.
Do NOT use bleach! Bleach will break down the bricks on a molecular level and cause them to be brittle. Also, do NOT put decorated bricks in the peroxide. I have had mixed results but can tell you for sure that it WILL strip the gold off of old space bricks.
I haven't checked the links posted above, but imagine they instruct along the same lines that I did in this post.
About £1.50 in boots - you could dilute this 1:10
I'm going to give this a go with some random old white and blue bricks, with 3, 5 and 30% and see what happens.
I'll keep you posted.
Another trick is to put aluminum foil behind/around the side of the jar that is not facing the sun (if, for instance, you have it on a window sill). I've had very good results with everything I've tried, but it takes sunlight and TIME. Change out the peroxide if you keep the parts in more than 5 or 6 days.
I would hesitate to use anything stronger than 3% again that is 3%. SOme transformer collectors noted that the 30% was too strong and could actually damage the plastic.
I wouldn't be surprised if 30% is too strong and makes them brittle - look at what it does to my hair!!! ;-)
http://www.bricksetforum.com/discussion/612/restoring-uv-damaged-lego-i-didnt-believe-it-till-i-tried-it-myself
(BTW, the other thread has to do with non-treated bricks, this thread has to do with the chemically treated bricks) This works with varying degrees of success.
As I understand it (and I'm no chemist!), there's a flame retardant in LEGO that contains Bromine. When UV light hits the flame retardant, it has the ability to break the chemical bonds. Under the right circumstances, Bromine atoms bond to other Bromine atoms, forming Br2, which is sort of yellowy-brown. If this happens too much, the yellowy-brown color becomes more pronounced, and your bricks look ugly.
However, (again, as I understand it) UV light ALSO has the ability to break down Br2 molecules. Again, under the right circumstances, the loose Bromine atoms can re-bond properly in place rather than in Br2.
That means basically that depending on the particular batch of ABS that you have, the particular color, the strength and directness of the UV light, and other conditions (ambient heat, moisture, pressure, whatever), UV light can be either repair or destroy the color of your bricks.
Using the chemical treatment (like Retr0brite), I believe the randomness is reduced, forcing the loose Bromine atoms to prefer their initial state (bonded to the flame retardant) rather than being bonded to other Bromine atoms.
But that's my non-expert-uninformed understanding. Hopefully someone with a better understanding of chemistry can provide a better answer.
DaveE
"However, (again, as I understand it) UV light ALSO has the ability to break down Br2 molecules. Again, under the right circumstances, the loose Bromine atoms can re-bond properly in place rather than in Br2."
Not quite. I believe bromine bonds with oxygen in the air. The idea is not for the bromine to re-bond to the flame retardant from which it originated, but to bond with hydrogen so that it is not an ugly yellow color.
UV light is simply an energy source. If you recall activation energy from chemistry class, most chemical reactions need the addition of energy to get going. A piece of paper will not spontaneously burn. You need to add energy by heating it up. Once a certain threshold is passed, it goes downhill and releases energy. The paper burns and turns to ash. However, this only happens if there is oxygen present! If you heat up paper in an environment without oxygen then it will not burn. That's the idea behind UV exposure with ABS plastic. UV light energizes the bromine atoms allowing various chemical reaction can happen. In an oxygen rich environment, like the air, this reaction results in oxygen attaching to the bromine. In hydrogen peroxide, a hydrogen rich environment, this reaction results in hydrogen attaching itself to the bromine. You want hydrogen because it doesn't make something that is ugly yellow like the oxygen does.
I've just built "build a bob" and just a handful of the yellow pieces are a different yellow. I'm not sure if it's discolouration or if some older/newer pieces have crept in. (it was in a bulk buy and mostly constructed, and I'm too lazy to deconstruct it, as I was just checking it for re-sale)
Also, how's H202 on bley and dark bley?
Also, what happens to pieces if they are in the H2O2 process too long?
That's neither here nor there, though. I, too, am interested in knowing if a printed piece will survive the de-yellowing process. If not, I'll pick up an extra troop builder to replace this piece with, but I'd prefer to just salvage the one I have.
Are they just in too long? Are they just too far gone? Is there anything I can do to get some shine back? The pieces look good when wet!
Also, ironically Cellulose Acetate, the plastic that ABS replaced in 1963, has a tendency to not lose its' whiteness... but had the unfortunate side effect of warping (over long periods of time). So some of you will find white classic windows/doors that have stayed a very pure shade of white. And that is due to them NOT being made of ABS plastic... and apparently not affected by discoloration.
"Island Girl Sea Glow
A cleaner and conditioner similar to Crystal Clear, except it has the added property of dramatically improving white and other bright colors of gel coat and vinyl. It converts UV to visible light with almost startling effects. Both Crystal Clear and Sea Glow restore flexibility to old vinyl. Sea Glow is also effective in keeping sneakers looking like new and white. Simply spray on and wipe off, works on contact. Use a soft bristled brush for heavily soiled areas. An excellent sneaker cleaner/whitener."
and by the way, i was able to get the STAMPs off intact and onto a label sheet for later use!!
I do wonder if that Sea Glow stuff would offer some protection from it's description?
One note, @LEGO_Nabii mentioned there could be issues keeping bricks in the dark. That said, I'm skeptical because I'm not quite sure what the mechanism is for that. I suspect that yellowing in storage can occur from other oxidation processes. Basically, in an oxygen environment oxidation will eventually occur. UV light accelerates the effect.
Here is another article about ABS yellowing that I don't think was posted before (might be wrong): http://www.vintagecomputing.com/index.php/archives/189
@Deadareus I would not use a product designed to restore boats to process LEGO bricks. First of all, the treatment is designed for use with polyvinylchloride (PVC), polyester, and chlorosulfonated polyethylene. It is not designed for use with ABS. Second, the treatment works by removing the oxidized surface layer, something I wouldn't want to do to LEGO bricks. Thirds, the product contains plasticizers to condition your plastic, but not necessarily ABS plastic. From the "Handbook of Plasticizers" by George Wypych: Not saying your bricks would break, but rather that the material properties of your bricks would most likely change. And finally, I would be concerned about the type of chemicals I would be putting on my bricks.
And before and after pics?
They are badly yellowed so I can put one in the standard peroxide at the normal strength. one in tap water and one using a whitener from above. then see
Soaking in the sun:
Before/After:
You'll have to be more hands on with colors - if they stay in too long, they take on a white, cloudy appearance. Like those blue wedges in the glass pan - they looked pretty good after 6 hours but I was greedy and wanted all the yellow out. So I soaked them for another 12+ hours and now they look cloudy in spots.
I also had plain yellow bricks in for 20+ hours and they came out fine so it depends on the colors.
