The number in the sets owned box uses the piece count recorded in the database for each set.
The number in the parts box is the sum of the parts in the inventories that LEGO has published for the sets you own.
If you only own sets from, say, 2010 onwards, the numbers will be closer than if you have a lot of older ones.
say you had a set with 100 bricks from 1989 and Lego has 80 of those bricks still in production and/ or available (in sets, or as replacement bricks, customer service etc). The parts section will show 80 and the database will show 100. The more recent the set the more likely the two numbers will match, the older the set the more likely some bricks, plates etc will be out of production and the numbers won’t match.
I can't see the use of such info, if only to confuse some folks.
When you are missing a part you'd go look for it on BL or BnP. You won't go to the brickset page of that set and see "oh this set has 189 parts out of 214 pieces still available".
It would be most helpful if LEGO color names were easier for us common folk to relate to the actual color of the parts in question. Right now most of the color names are similar to those that the car companies use...BL's arguments for the color names they use are usually along these lines.
