ACM Question
Broke4BricksBroke4Bricks Cape Coral, FL USAMember Posts: 4
Sorry if this not the right thread for this and no offense to vanilla but this is not the most intuitive forum to navigate. I've searched for some time trying to find an answer with no luck.
My question is as follows
When modifying a set using ACM that had been built, ,disassembled, bagged and returned to it's original box. Would you initially choose Bagged Up, Boxed, Assembled? And then ✔  the boxes for the elements that are present  Parts, Minifigures, Instructions, Box?
  • HuwHuw Brickset Towers, Hampshire, UKAdministrator Posts: 7,059
    You can use it as you see fit and in a way that you understand. It's your data, visible only to you.
