Glitch in changing own 1 to own 0
snowhitiesnowhitie Member Posts: 3,078
I noticed this last week, but thought it was a temporary glitch, however, it's still persisting so I thougth I'd better launch a report.
I use Firefox on Windows 10. When I go into my set lists (more specifically spare minifigures), I've been selling a couple of things, so certian things I own have changed from '2' to '1' or '1' to '0'. When I change the amount from 2 to 1, it registers correctly and I can also delete the ACM of the double that's gone. However, when changing the amount from 1 to 0, that just doesn't register. Moverover, the number then becomes bold and back to number 1. I can unclick the checkbox obviously, but that does not get rid of the ACM.
Here's a screenshot of one of the bold numbers, I had just changed to 0, but it changed back.
This also happens when you have a list of lots of sets underneath each other.
Hope you can help, let me know if you need more info.
  • HuwHuw Administrator Posts: 7,076
    You can't own 0 of a set. You either own it or you don't, so just untick the box rather than entering 0.
  • snowhitiesnowhitie Member Posts: 3,078
     Makes sense but how do I delete the ACM info then? Thought this is how I used to do it, change it to 0, then you can 'delete' the ACM.
    The ACM entry will be hidden if you indicate you don't own so no need to delete it.
    Okay, thanks. I thought they'd still show up in an excell export, but I guess I must remember it wrong and only gone from 2 to 1 before and never from 1 to 0 :) Sorry for the confusion and thanks for the help.
