Please use our links:
LEGO.com •
Amazon
Building mini from 75894 in brown, need replacement part for 6252037 - help please!
I'm trying to re-build the red mini from
#75894 in reddish brown for a Valentines model for my wife as it was her first car in 1980. I assumed it would be a straightforward job of swapping out the red bits for brown ones, except that some of them aren't available in reddish brown! I can adapt all of the bits that aren't available in the right colour except for one, where I'm struggling and would appreciate any suggestions.
It's part 6252037 I can get in reddish brown and can't work out how to replace it and still keep the accurate lines of the model. This one:
It goes here:
Any suggestions hugely appreciated. Thanks
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
You'll need to fix the boot on using only two technic half pins (top and bottom) and you lose the illusion of the back seat. I think the rear windscreen should still fit around those extra studs though...
https://www.bricklink.com/catalogItemIn.asp?P=6091&in=S&colorID=88&ov=Y
You'd just lose the back seat and have the rear boot assembly just connected by one stud instead of three.
I've tries those @Brainslugged, but the depth isn't sufficient because of the placement over the wheel arch assembly, unless I'm missing something.
Appreciate the suggestions. Looks like I'll be able to muddle it through now. Just need to give my friend his mini back and try and get one of my own without breaking the bank.
