Type of bricks for water effect
landolando Member Posts: 108
for the water effect are the 1x1 round my best bet and is eBay a good place to buy I need a lot
  • milambermilamber Mayenne, FranceMember Posts: 636
    Worth checking out the online manual for 70620, Ninjago City, and looking at the technique used for the water effect with that. It uses transparent blue tiles over solid ones to give a very good impression of water and varying depth.
    I've always found Ebay far more expensive than Bricklink or directly from Lego, but you might strike lucky.
    There are loads of different effects for creating water with LEGO, it's personal preference which you decide is "best" for what you're building.  Assuming by 1x1 round you are planning to "parts dump" like #21313 Ship in a bottle to create the effect?
    I'd guess eBay would work out rather expensive for buying loads of 1x1 round plates/tiles and unlikely you'll find someone actually selling them in large quantities.
    Best bet would be to have a look at LEGO Bricks and Pieces, BrickLink or BrickOwl and compare prices there.  Not sure if those types of parts show up on the Pick A Brick wall at LEGO brand stores at all, but if you have a store nearby you could check that out too - you'd get quite a few in a Pick a Brick Cup!
  • landolando Member Posts: 108
    Yes the effect same as ship In a bottle. And your probably right it would cost quite a lot buying lots of them.
    Ok thank you will check out the ninjago city
  • CCCCCC UKMember Posts: 20,362
    PAB walls often have trans blue 1x1 round plates.
    lando
  • Switchfoot55Switchfoot55 The Northwest, USAMember Posts: 2,742
    If you're looking for other ways of going about it, I'd check out Pintrest. It's a treasure trove of ideas.
    lando
