Hello,
Having played extensively with LEGO Technic as a youth (I still have the
original 853 Car Chassis Technical set), I now find myself playing with
LEGO Technic with my son! I am a vehicle design engineer by trade and
this combined with the time spent playing with LEGO Technic resulted in
an idea for a new Technic compatible part. After this idea had knocked
around in my mind for some time and refused to go away, I decided to
design in properly using 3D CAD and present it to the Lego Group to see
what they thought.
I put together the following video and sent it by e-mail to the LEGO
Group several months ago, but I have had no success in getting them to
take an interest in the proposal:
VIDEO: >>>>> https://www.youtube....h?v=93H82WU8txM <<<<<
My design cannot be submitted through the LEGO Ideas web site, because
new part designs are specifically excluded. However if I can get to at
least 10,000 views on YouTube (the LEGO Ideas review threshold), I think
LEGO Group may be prepared to give serious consideration to producing
these new parts. If you like the idea please help by sharing this video
on social media, in forums and with friends.
Thank you for your help.
The key design features are:
1) Planetary gear train built into a standard 56x34 rim - the gear train provides a 3:1 speed reduction and a corresponding 1:3 increase in torque. The output torque is generated at the internal gear and transmitted directly to the rim and from there to the tyre or track, therefore it does not pass through any axles.
2) Integrated 14 tooth track drive sprocket - increases potential applications, the rim flanges provide lateral support on the underside of the track segment plates. The sprocket is hidden when a tyre is fitted.
3) 4-point universal mount - this is designed to accommodate: rigid axle, rigid axle with steering, suspension or suspension with steering set-ups, all utilising standard components. The pivot point is positioned to allow the use of either a one part universal joint or a 2 part cardan joint.
4) Rolling element bearings - provide authenticity, tight rim location with little free play and also give low rolling resistance.
Also, I think the fact that it has bearings will be it's downfall. Lastly, getting to 10,000 views on YouTube is far easier than getting to 10,000 on ideas - I can't imagine lego would give that any credence at all to be honest.
My ultimate aim is to add a set of parts to Technic that allow realistic functional models to be built, "authentic" in LEGO speak. I love building things in LEGO Technic with my son that demonstrate engineering principles; learning that occurs through play is fun. These parts produce a planetary hub that is close in design to real world parts, that is why I included rolling element bearings.
I agree that views on YouTube is not the same as votes on Ideas, if only I could, I would have put this on Ideas - what else can I do?
As for the idea itself, I personally think it is unnecessary and over complicated. From the video I honestly don't see anything this does in actual functionality that people can't already do with Lego parts.
"We cannot produce new LEGO parts molds, new cloth or other non-brick elements within the scope of LEGO Ideas, and therefore we don’t accept projects that include these items. Existing parts in different colors are okay, as well as new stickers or printed parts." ( https://ideas.lego.com/guidelines )
Key design features:
1) Planetary gear train built into a standard 56x34 rim ( http://brickset.com/parts/6065490 ) - the gear train provides a 3:1 speed reduction and a corresponding 1:3 increase in torque. The output torque is generated at the internal gear and transmitted directly to the rim and from there to the tyre or track, therefore it does not pass through any axles.
2) Integrated 14 tooth track drive sprocket ( http://brickset.com/parts/4582792 & http://brickset.com/parts/4566742 ) - increases potential applications, the rim flanges provide lateral support on the underside of the track segment plates. The sprocket is hidden when a tyre is fitted.
3) 4-point universal mount - this is designed to accommodate: rigid axle, rigid axle with steering, suspension or suspension with steering set-ups, all utilising standard components. The pivot point is positioned to allow the use of either a one part universal joint ( http://brickset.com/parts/4525904 ) or a 2 part cardan joint ( http://brickset.com/parts/4610374 & http://brickset.com/parts/4268659 ).
About the YouTube views: I think likes are a better representation than views, but still not the same as supports on Ideas.
