Please use our links:
LEGO.com •
Amazon
Difference between 10213 and 10231 Shuttle adventure and expedition?
I have got either
#10213 or
#10231, but I am unsure which as they look similiar. Is there a way to tell the difference_? Or are they the same apart from added hair in 10231?
I am going to sell it and one set seems to be worth £50 more than the other....
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
Quick Links
- The fuel tank has been reinforced with supports to strengthen the assembly
- The landing gear is strengthened to function better across many different floor types
- The Cargo doors can now be more rigorously opened and closed
- The entire build has been reworked to limit opportunities for misplacing elements
- Astronauts now have wigs in addition to their helmets (1 male, 1 female). Face prints are also different.
- The new set now has 1,230 elements
- New Satellite can be securely positioned on the new mechanical arm
I'm not sure you will get any more for this than Shuttle Adventure unless there are exclusive parts. You obviously don't have the instructions or the box, so it is just a matter of pieces that can be purchased anywhere.
The best clue was the faces... I didnt think they would be different, but they are. I have the 10213.
Thanks for your help.
http://www.bricksetforum.com/discussion/comment/106474
How the first one got the green light, I don't know. Wet tissue paper has more structural integrity.
I've never used it as a play item but it has survived two moves in tact although don't look too hard at the external tank as it does have a habit of exploding at the top . . . . .
Maybe I should see about getting a supplemental pack, or most likely not!
According to Rebrickable, leftover parts are all those 1x1 plates, tiles, slopes etc.
http://rebrickable.com/compare/10213-1/10231-1
