What you could do (and it would be time consuming), is to use the self timer. I'm assuming that you're going to have the camera on a tripod for stability, you'd then set the camera to self timer mode, press the shutter, and you'd have about 10 seconds before the shutter fires, giving the camera time to stop any wobbling.
To be honest though, if the camera's on a tripod, you have a light touch, and the model is well lit, so that you have a shutter speed of about 1/125 or faster, you shouldn't get noticeable shake.
The other form of "shake" is more wobble over shots due to the camera changing position. Even on a tripod it is possible to move the camera when pressing the button. So make sure you press it very gently, or use a very heavy weight pulling down on the tripod so it doesn't move.
