Im a power functions guy but perhaps you might find your answer at this website.
@ ecmo47 thank you, i am not sure if you mean this actual web sit or if you left a link but i can not see it? thank you.
kind regards
Andrew
sorry, i found the link..thanks again
Don't press too hard as you may crack the metal and also be aware that it leaves a white residue on the plastic part of the track when it dries - I used a soft toothbrush to get rid of that.
Also, I know from the past and real train sets as a kid that if the track is too big it does lose power.
I'm not sure if it's simply the case of adding a second power supply to the track or how it works as my current 9V setup is quite small when I use it - 10 straights and 16 curved sections though I have a load more curves...
You may also have problems from bad track connections... I actually have bad 9V track that I've isolated and removed from use on layouts because of it. I couldn't tell you exactly what's wrong with them, just that they create dead spots.
Lastly, since I'm writing a novel here, if that might be an issue, ME Models is pre-selling 9V compatible track. I bought from them when they previously had it, and it worked great, but they went back to the drawing board and created a kickstarter project to fund a new design. The interesting aspect is that you can get double length sections (and in their first incarnation, quadruple length sections) that reduce the connectivity problems by requiring less track joining. I have no idea when they will actually ship, though... the drop dead sign up date isn't until October.
Some tracks just go bad. I had a few that just didn't work. I tried cleaning them and fiddling with them and they were just poorly made.
So yes...multiple connections along the track will ensure the voltage level is maintained. Just make sure the polarities are correct at the points of connection.
You can buy these to hook to your track connectors.
The reason I am asking is because I have had approximately 130 feet of track connected in a single line, not a continuous loop and finally encountered his problem near the end of the line.
thank you all for your help. i will give cleaning the track a go and i think that due to have over 50 tracks i will need to Add another connector from the same power source.
Is there a limit to the connectors that can be added ?
Again thank you for all your advise and help.
kind regards
Andrew
hopefully i can give some good news next week.
I must have about a 250-300 9V track layout, with several splits. They have been on display in my room for many years, and some are even from way back in the early 90's. A few years ago I found that, after not using them for a couple years, the ability to run my train on them became very limited. So I used a damp cloth and had to vigorously rub them. I had assumed the accumulation of dust had coated the rails and negated the contact between the rails and the train. I was surprised at how much rubbing it did require. I had to apply firm pressure often with the very tip of my fingers (definitely a brutish technique). @GIR3691 you mention patina, but there was no visible sign of any patina or like-defect on the track.
Well, my desire to run trains took another hiatus (2-3 years) and today I find that my track is back to the same condition. I really had a tough time cleaning all the tracks the previous time, and was hoping to find an easier solution. I see above @beegeedee mentioned Brasso. I wonder if anyone else has other ideas. Using a soft cloth seems reasonable enough but I feel like something more abrasive would have been better to use.
@fletch I agree with some above that just a thorough cleaning will solve the problem. But what is the best technique is the real question.
My understanding is the dirt is due to oxidisation from the electric current running through the track but I may be wrong.
