66005 - Blue Arch 1x3x2 with Curved Top - 4
4589 - Dark Grey 1x1 Cone - 1
30179 - Dark Grey 1x4x6 Door Frame Type 1 - 5
2429 + 2430 - White 1x4 Hinge Plate top and bottom - 12
970c00 - Sand green Minifig Legs - 1
41879 - Red/Brown Minifig. Short Legs - 1
3045 - Light Grey 2x2 Double Convex Slope Brick - 8
3070b - Light Grey 1x1 tile with groove - 42
4035 - White 1x2x3 Train Window - 4
If you're not adverse to substitutions, you could probably use type 2 door frames. Also look for the cones with the top groove. The ones without the top groove are not manufactured any more and are being all bough up by people trying to complete a 10179, which is why they are hard to find. There may also be similar windows that would work as well. With the hinges, look for the complete assembly. I believe there are more sellers selling the completed assembly than the two parts separately.
I hope this helps a bit and good luck finishing your GG!
I will definitely try the substitutions for it. Thanks again.
I don't necessarily start with the seller with the most items I need. I try to start with the rarest/most expensive items. I buy them from the cheapest sellers, then also buy whatever else they have that I need. This way I'm not stuck with the expensive, hard to find parts at the end. Not that this helps you now... but maybe for a future project.
So I made the orders worth it to me.
Thank you again.
Having said that, I purchased one of the hair pieces (and nothing else) from a seller in America, because even with the postage added on, it was still cheaper than getting it from a seller in Europe.
I didn't get the sand green colour, I changed that, so all these parts were cheaper for me than paying through the nose for sand green. I have no intention of selling this modular, so changing the colour was fine.
1. Instead of Sand Green bricks I used Green.
2. Instead of a Type 1 Door Frame I used a Type 2.
Everything else is the same colour, the green bricks have the grooves, even the white cat with the printed face has been included. I chose the green bricks because I wanted it to stay close to it's original form. I disliked the colour of the Olive Green and the Bright Green was way too bright. Most people seemed to be using Sand Blue, which is very nice, but I wanted it to be different. Plus later if I choose I can just change the green bricks to Sand Green or what ever colour I want.
