Help with Set #3723 Arm connection.
TheBrickLaddTheBrickLadd Chippenham, Wilts, UK.Member Posts: 844
Hi all, has anyone built this set and had issues connecting the arms? Im either being really thick or just too tired to read the instructions properly.
Any help or explanation would be helpful. :D
Cheers
    Is one arm attached to the body differently than the other one?
    edited April 2014
    A and B are two different ways of building it. With A, the three bricks on the right side of the B box, are left out and you use the axle and 2 wheels on the body side, and on the arm you use 2 pins. This makes the arms static and allows them to be positioned.
    With B, you put in the 3 bricks on the right side of the B box into the indent where the wheels are in A, and connect the arm with the single pin. This allows the arm to freely swing but will always just hang straight when you arent holding them up.
    It is either A or B not both.
  • TheBrickLaddTheBrickLadd Chippenham, Wilts, UK.Member Posts: 844
    Thanks that make so much more sense! Option B it will be.
    Cheers @graphite
