As for your questions, I recommend using waterslide decals for the printing, which can be got from many craft stores.
For custom weapons, either Littlearmsshop or Minifigs4u are great. I would give links but I cannot since I am on my phone, Google will find them though :o)
Good luck Amos!
How do I the decals onto the waterslide sheet? are there any printable decals available somewhere?
But on topic again, +1 for the Arealight parts, though. There's a lot of variety and designs and they look to be great quality.
I think you can usually get waterslide decal paper in hobby/craft stores, and it's usually printable (ie, you stick it in your printer and print straight on to it). I'm sure there are plenty of decal sheets out there - just google for them.
Here's Little Arms Shops SW weapons:
http://www.thelittlearmsshop.com/store/home.php?cat=26&sort=orderby&sort_direction=0&page=1
But I couldn't find minifgs4u's site.
Here are some good decals which you might like to use.
1. Get a blank white torso and scan it into a program such as MS Paint at a high resolution (I use 600dpi) using any good quality scanner.
2. You should end up with something like this:
Save it in a lossless format (i.e. a PNG file).
3. Import into Photoshop (or similar program, but can also be done in a basic program such as Paint). Crop right to the edges of the torso as shown:
4. If you're creating custom torso decals, now be creative! Here I use a simple logo-based design, but you can also draw straight onto the torso, so for example, in @rancorbait's case, he would draw or find torso detailings relating to Republic Commandos. A graphics tablet is handy here :-)
5. Save the torso design as a new PNG file. Import the decal into Word or Publisher (I use the 2010 version, your display may differ). There should be a setting that lets you input how wide or tall the image will be. Change the width setting to the measured width of a torso, which I found to be 1.48cm. The height should change with the width.
6. Print the torso decal and apply to your chosen figure using your preferred decal method. Here's the actual printed decal in relation to a minifigure:
I hope this is somewhat helpful not just to @rancorbait but to everyone interested in creating decals, I imagine this can also be done using a Mac operating system as well. This could also be done with printed torsos, just scan the decorated torso and skip step 4. Of course, your results may vary :-)
Thanks for the tips! Lets see if I can even get by step 1 :oP
This is what I got:
A thought did just strike me, though, for the basic armour (without the coloured bits), I would consider doing one half and then mirroring it, so it would be absolutely symmetrical. Then you could add the colours over the top of that. That might just be my OCD speaking, though. (That may be what you've done, and it's just the quality of the photo that's making it look slightly uneven, though)
